Stripping front bumper cover?
Guys, I need to replace my front bumper cover on the IROC. The replacement cover is Black right now with paint chipping. I need to know what procedure will work the best to strip it?
Sand it(the best bet). Or a chemical strip?
Brendan
1987 IROC-Z L98 350 SuperRam, Edelbrock Performer 6085 Aluminum Heads, LPE RollerCam 219/219, Crane Gold Race 1.6RR, TF 1 pc Chrome Moly Pushrods, Underdrive Pulleys, Edelbrock TPI High Flow Base Manifold, Accel 58mm TB, ADS 24#, Crane AFPR, K&N, Edelbrock TES Headers, Catco Hi Flow Cat, 3" Borla Cat-Back, Accel Cap & Rotor, MSD 8.5mm, MSD 6AL Ignition, MSD Blaster 2 Ignition Coil, Hayes Clutch, 1LE Aluminum DS, 94' Z28 Disk Rear, Wilwood Adjustable Proportioning Valve, Torsen Series 3 Posi Carrier, Precision 3.73 Gears, Southside Machine Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
Brendan
I'd sand it, the stripper might eat into the material. If I remember right, i used 80, then 120 then 200 then 400 grit, you will probably want to go finer than that though, I think my body guy took it as far as 1200. Of course he cheats and uses an orbital sander, I blocked it
good luck
good luck Thread
1992 Trans Am
May 10, 2023 07:19 PM
