Twisting Frame
Old Jan 24, 2001 | 06:11 PM
89FormulaL98's Avatar
Twisting Frame
when i bought my car it already had bolt on sub-frame conectors installed and the doors would close very easily..... however i get this paranoid feeling like the car is twisting dispite the sub-frame conectors it seems the doors do open as well as they used to.... can i get som info?
89' Firebird Formula WS6 L98, MSD 6AL MSD Blaster, Hypertech chip, K/N filter cone,flowmaster 80 series, hypertech air foil, koni shocks, edelbrock trailing arms
Old Jan 24, 2001 | 07:14 PM
i mean dont close as easy... opps
Old Jan 24, 2001 | 07:24 PM
Nightcruzer's Avatar
Car: Trans Am
Bolt on SFCs suffer from bolt hole elongation. With time and force, the bolts that hold the SFCs up actually stretch the metal around the holes they pass through causing a loss of twisting force resistance to the SFCs. Have them welded up. You won't ever have to worry about twisting force again and you'll have an great "frame" to start all your suspension mods.
Old Jan 24, 2001 | 09:05 PM
3rdGem's Avatar
Another thing to consider if your doors aren't opening/closing as smothly as they should: check the door hinge roller bushing for wear. That's also a cause for "sagging" doors.
'88 Formula 350
Bright (VERY bright) red. Mods? yep, but never enough!
Check out the newest f-body site: http://www.lastgen.com/
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
aaron7
Sep 30, 2015 09:15 AM
