Reducer substitute?
Old Jul 28, 2012 | 07:49 AM
MadCelt's Avatar
Reducer substitute?
Hey all. Hoping someone out there has advanced knowledge of basecoat/reducer. I'm painting with Sherwin Dimensions 6B base, and one of my kids tipped over my can of reducer, cap wasn't on tight (my fault) and it went all over the garage floor. So it's Saturday, jobber is closed, and I have no reducer (was using the DR734 as on data sheet). Is there anything I can use as a suitable sub that will give me good results? We have a CarQuest nearby that sells Dupont and some other generic stuff. I may be able to get a generic reducer, but don't know if I should do that...
It's too bad jobbers aren't open on Saturday for us hobbyists!
Old Jul 29, 2012 | 11:00 PM
steve87ta's Avatar
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
Re: Reducer substitute?
Dont know on that brand, depends on what their base is. Some are acrylic, some urethane.At my Work they have use use centari reducer (enamel) with imron (urethane) and it works ok but i would not recomend it.
Oh well it is sun now so you probably got a plan now.
Old Jul 30, 2012 | 08:12 AM
MadCelt's Avatar
I'm stopping at my jobber on my way home from work today, get the 'real' stuff. Put it off for the weekend.
Thanks for the reply though!
Old Jul 30, 2012 | 10:22 AM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Yes enamel reducer works with urethane and vise versa. Not specifically made for it but you can do it in a pinch if you have to do something small on the side. Same with hardener they have universal as well as single stage uerethane, single stage enamel, bc/cc type ect. They are made to work best when used with the same type paint but they all do technically "work" with each other.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Pac J
May 17, 2020 10:44 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
gord327
Oct 3, 2015 01:25 PM
dimented24x7
Sep 17, 2015 06:58 AM
