rattlin' windows!
Old Jan 30, 2001 | 09:26 PM
Remondi2's Avatar
rattlin' windows!
when i put the power windows down in my '87 iroc coupe they rattle like they're going to fall out. if someone shuts a door a little too hard with a window down, the sounds are so terrible i look on the ground for broken glass. i took the door panel off in retaliation, nosed around a bit, and the only thing i found was a worn away old rubber stoper on the rear bottom part of the frame that goes up and down with the window. i replaced these with similar stopers i found at a great hardware store around and continued to put my doors back on with all new trees(lowes). this was a pain to do and did nothing for my problem. the sound seems to be coming from the bottom front of the door, but that doesn't necesarily mean that is were the problem is. any knowledge or other findings on this subject would be greatly appreciated.
Old Jan 31, 2001 | 02:31 AM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
my guess is either there are some nylon bushings on the window tracks that are worn or you missed some of the rubber pads inside the door somewhere...
Webmaster: www.IROC-Z.org
Old Jan 31, 2001 | 02:11 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Check the metal tabs that have that felt stuff on the top of the door frame. They need to be adjusted.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Jan 31, 2001 | 03:51 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
https://www.thirdgen.org/newdesign/t...owadjust.shtml
Looking For:
87 IROC-Z 350 TPI
84 TRANS AM 305 H.O.
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
