17x9 wheels
17x9 wheels
Will I need any spacers to fit 17x9 wheels on? What are the specs I should work with?
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN93, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL, Holley 9mm wires, fastchip, Bosch O2sensor, Bosch in-line pump(w/stock pump), SLP headers & catback,short shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
depends on the offset you choose. The width and diameter has nothing to do with whether you'll need spacers or not.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
I'm planning on using Primax 460 wheels. 17x8
I don't know the offset yet..
91 Formula
305 TPI 5speed
1LE/G92/WS6
91 Formula
305 TPI 5speed
1LE/G92/WS6
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
You can go with 5.5 inches of backspacing. With this rim you can run 275/40R17 tires, and they won't rub. They won't rub even if your car is lowered an inch or so! One small problem; you may have to grind your outer tie rod ends to gain clearance. This is REALLY unlikely, but it is possible. By the way, American Racing makes Torque Thrust 2's in a custom 5.5" backspacing that meets this application. These rims look bad as hell with our cars!
drptop70ss
Oct 4, 2015 09:44 PM
punkmaster98
Sep 8, 2015 09:45 PM
