17x7 Primax #618 Racing wheels.Fits 5x100 and 5x114.3 bolt patterns.+38 offset
Old Feb 5, 2001 | 11:14 PM
theformula's Avatar
Will these rims fit? If not, what will I have to do to make them fit.
thank you
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN93, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL, Holley 9mm wires, fastchip, Bosch O2sensor, Bosch in-line pump(w/stock pump), SLP headers & catback,short shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Feb 6, 2001 | 08:18 PM
Frank 84 Bird's Avatar
Car: 87 Trans Am
Transmission: TKO 600
Those wheels won't work. Our cars have 5 on 4.75 bolt pattern which is larger then 5 on 100 or 114.3. The offset is for a front wheel drive.
Later
Frank
Old Feb 6, 2001 | 11:30 PM
GMI FAST's Avatar
Our pattern is 5X120.65mm...
Old: 1989 Formula, 383", DFI, built 700R4, TFS heads, Mini-Ram, Vortech S-trim 15 psi, 3.70 gears
Best ET: 10.796 @ 125.8 mph
New: 1989 T/A, 400" CNC Bow-Tie Tall-Deck, Accel Pro-Ram, DFI, AFR heads, HRC T76 Turbo, NOS 150-hp dry kit, TH400 w/GV overdrive, 12-bolt w/3.70 gears, 8-pt. S&W rollbar, Spohn suspension, 18" wheels, Baer brakes
Best ET: Spring 2001
Employed at:
Hahn Racecraft
Accel EMIC/DFI Tuning
Turbosystems & Custom EFI
Member of Midwest F-Body Association www.mfba.org
Old Feb 15, 2001 | 09:15 PM
Fiero_Freak's Avatar
Car: 2014 Camaro 2SS/1LE
Engine: 6.2L LS3
Transmission: Tremec TR6060
Axle/Gears: 3.91
did you buy those? or just looking at them? How much are they?
Old Feb 15, 2001 | 09:22 PM
theformula's Avatar
Fiero, they're on ebay for like $350 for the set. Just type in PRIMAX
Hotrodboba400
Dec 10, 2019 07:07 PM
billybob6110
Sep 23, 2015 01:30 PM
Amillionoh7
Sep 5, 2015 11:44 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
