Power door lock doesn't lock all the way...
Old Feb 17, 2001 | 04:30 PM
Baron's Avatar
Driver's side - it closes until you can't see any orange, but in order to be locked I have to push it another 1/2 inch closed...how big a problem is this?
'89 RS LO3- 140,000 miles
14x3 K&N Open Element
Ram Heavy Duty clutch
Edelbrock TES (Jet-hot coated)
Catco cat
Edelbrock 3" Cat-back
Pioneer DEH-P77
Dual .50 caliber machine guns just under ground effects
Coming:
KYB shocks
Edelbrock Strut Tower Brace
South Side Machine subframe connectors
When your buddy reaches for a 10-pound sledge and says "I think we're gonna have to modify the floor pan, okay?" the answer is NO.
Old Feb 17, 2001 | 05:01 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I had the same problem with both doors. I simply removed the door panel, then cleaned with WD-40 until the lock mechanism functioned properly, then I coated everything liberally with white grease. While you're in there, do the power windows too.
JamesC
[This message has been edited by JamesC (edited February 17, 2001).]
Old Feb 17, 2001 | 10:32 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I did just like JamesC said.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Feb 18, 2001 | 02:23 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Yup, that will fix the problem
Old Feb 18, 2001 | 07:13 PM
Tom Batts's Avatar
Old Feb 19, 2001 | 10:57 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I agree with the lubing of the rods and mechanism suggestions. I recently did mine. Not that I was having any problems, just for "preventive maintenence". Also check that the rods are still in their plastic guides as well.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackTopKing
Aug 19, 2015 12:13 PM
