T-Top Weatherstrip Replacement
Old Sep 12, 2012 | 04:57 PM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Transmission: TKO500
Axle/Gears: Moser 9" 3:50
Hi All,
I have purchased the Hawks T-Top Weatherstrip kit.
I live in the Raleigh NC area.
Can anyone recommend a shop to replace the seals?
Best Regards,
Bruce
Old Sep 12, 2012 | 05:11 PM
82tarecaro's Avatar
Re: T-Top Weatherstrip Replacement
Is that the OER kit? I haven't heard anything good about that kit.
Old Sep 12, 2012 | 05:29 PM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
It is my understanding that this is not the OER kit.
Old Sep 12, 2012 | 05:34 PM
82tarecaro's Avatar
What brand is it?
Old Sep 12, 2012 | 06:44 PM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
I am not sure?
Talked to Hawks before I purchased the kit. They indicated that this kit was sourced due to availablility problems with the OER kit.
Old Sep 12, 2012 | 06:49 PM
82tarecaro's Avatar
That's good. You would not have liked those seals. Are you handy? They are not hard to do. Just a lot of work. If you do some reading here there are some good threads on installing them.
Old Sep 12, 2012 | 07:26 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
A shop would charge you a lot of money due to the time involved. Plus, there are a lot of variables in possible rust/damage you'll have to pursue. I know; I just finished mine and it was LOTS of FRICKEN WORK!!!!!
You won't know how much till you start removing what you have and see if there's any rust, or if it's been replaced in the past and done wrong. Lining up the seals into their precise spots takes a careful eye. You need to use the correct sealant, etc. Nitro
1992 Trans Am
May 10, 2023 07:19 PM
gta90
Sep 15, 2015 04:00 PM
g.l.mos
Aug 22, 2015 12:02 AM
Penultimo
Camaros Wanted
Aug 20, 2015 08:42 PM
qz6lwp
Aug 20, 2015 08:10 PM
