3rd brake light out?
Old Sep 13, 2012 | 03:06 AM
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
On my 91 rs, the brake light isn't working. The light is on the window, inside the car. I've replaced the bulb, checked the wiring, (all of my fuses are good). Any suggestions on what to try?
And if someone doesn't mind telling me the correct bulb i should use? I've tried plenty of different ones.
Old Sep 13, 2012 | 10:06 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 3rd brake light out?
Check were the hatch closes on the contacts were the pull down switch is,might not be making contact.
Old Sep 14, 2012 | 07:54 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
He doesn't have that in a 91. All the connections are in the ceiling.
Can you get the light to go on by supplying power to the connector? Does your dome light work?
Vintageracer
Jan 10, 2020 05:33 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
