Water Leak above the rear seats. Where is it coming from?
Hey guys.
I have an 86 Transam w/ T-tops. I've replaced the weatherstripping for the rear hatch and the T-tops. It's leaking water above the panel right above the rear seats. You can even tell the headliner is a little stained. anyone ever have this problem? Where is it leaking water?
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It's leaking underneath the black metal bar that is between the two t-tops. It runs through the channel between the tops right to the back, then runs through the plastic rail near the hatch, and drips onto 1 seat or the other. If you parked with the car facing down, it would come out near the dome light or through the swivel light in the overhead console. It's a pain in the *** . I sealed my tops as good as possible and it still leaks. The only solution is to pull the gaskets out, pull the black piece back up, and silicone around the holes in the roof panel. If the gaskets are original or if you cemented them in, you're going to ruin them when you pull them out. Like I said, it's a pain in the *** .
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
In my car, it leaks where the hatch back hinges bolt to the body of the car.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
-Justin-
hehe mine leaks where the side windows fit against the t-tops at the back. i think the side windows are adusted adjusted out too far. is it hard to adjust them in more? i have power windows.
jeremy snyder
jeremy snyder
Everybody is mentioning very common leak-points, but the only two that would cause it to drip from the plastic panel he mentioned is the style leak that I have or leaking through the hatch hinge bolts like Justin mentioned. I thought it was leaking through my hatch hinge bolts at first, so I took them off 1 by 1 and siliconed them, and put them back on. I was very miffed when my back seat continued to get wet. I'm going to have to fix this problem before I put my leather seats in!
The IROC Homepage
The IROC Homepage
hectre13
Dec 11, 2023 08:14 AM
Street Lethal
Aug 12, 2015 11:33 AM
