Switching 4th gen gauge cluster into 3rd gen
Is it possible to switch a 4th gen gauge cluster into a 3rd gen without changing out the whole dash?
91 Camaro RS, 305 TBI
92 Lumina, 275,000mi and humping!
No mods yet...Hopefully:
Convert to dual-cat with headers and Borla catback exhaust.
350hp 305TBI I dont care what you say!!!!
RAM air hood & Z28 wing.
ABS system.
Positraction rearend with rear disc brakes.
Rebuilt front and rearend suspension with polygraphite bushings.
Strutbrace.
Rollbar.
Subframe connecters.
ABS system.
Strutbrace.
Rollbar.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
no.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
It can be done, I have see it. The only problem is if you want everything work right you have to have a LT or LS motor to work right with ECM and tranny. The width is about the same but I know there is alot of diffent issues to go through. Where the radio and HVAC goes down there is an issue with the hump for the dranny being a differnt size. I don't know the guy personally but I talked with him onces at Porky's (local crusing spot) and those were the big things that he had said.
