Converting automatic to T-5 manual please help!
Old Mar 14, 2001 | 11:23 PM
vortech305's Avatar
I have a 92' camaro with the stock TH700R4 in it and bought every single accesory for the swap. I know i must cut a whole in the floor under the console but what exact length and width. Its a stock t-5 thats going on. One more thing i bought a 92' manual shift plate from a camaro is this all i have to change or do i have to change the whole bottom console.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Mar 14, 2001 | 11:56 PM
cvpde37's Avatar
As far as the console goes you need the lower boot and the top plate. Can't help on the hole. You might check the main page, there is a tech article there that I think is pretty thorough.
1984 Z28 350
Never argue with an idiot, they'll just bring you down to their level and beat you with experience
My Web Page
Old Mar 15, 2001 | 02:29 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
No you have most if it down. What I did was bolt up the tranny, then jacked it up until it hit the trans tunnel, marked around the shifter mount, lowered the trans, then measured about 1/2-1" around the hole and put 4 punch marks, one in each corner.
Then from the inside, after the console is out, took a dremel with a cut off wheel, quite a few, cut out between the punch marks.
The upper shift plate is all that you need for the conversion.
If the women don't find you handsome they should at least find you handy
88 GTA Notchback with 91 gfx and ROH Snypers
Aftermarket T-56 (pain in the A$S but worth it)
Lots of things to do still
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
angel2794
Sep 8, 2015 06:22 PM
Cacike
Aug 27, 2015 05:10 PM
