Regular hatch assembly to power hatch assembly
Old Mar 15, 2001 | 09:57 PM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
I am trying to swap my regular key-operated hatch release in my 82 T/A with a power hatch release from an 86. Im wondering if anyone has done this, and what is the best way to go about this. I dont need info on the wiring, i can figure that out cause i have the donor car, but i need to know the best way to actually remove the power release mount and the lock assembly to switch it.
Old Mar 21, 2001 | 04:19 AM
ZANG's Avatar
THE LOCK ASSEMBLY DOESN'T NEED TO BE REMOVED , IT IS ONLY ATTACHED BY A CABLE.
JUST UNBOLT THE OLD ONE AND INSTALL THE NEW ONE.IF U WANT TO CHANGE THE LOCK ASSEMBLY REMOVE THE CENTER SECTION OF YOUR TAILLIGHTS AND U WILL SEE THAT IT IS RIVETED IN.DRILL IT OUT AND USE BOLTS TO PUT THE NEW ONE IN
Old Mar 21, 2001 | 11:34 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Sorry chief. It's not that easy. The cars with the power assembly have an entirely different mounting system. You would need to cut the steel mounting panel out of your car and weld in the one from a car that came with the motorized system. As soon as I got my 85 IROC I planned on moving the motor from my 86 over, and realized that it just ain't gonna happen.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Mar 21, 2001 | 11:40 AM
92RSMAN's Avatar
what if you have a pull down hatch motor but there is no switch....do you just need a switch?? would like to get that feature for sure.
Pure Black 1992 RS Camaro
CHECK OUT MY SITE! http://www.angelfire.com/ne/92rscamaro/index.html
Old Mar 22, 2001 | 04:46 PM
92RSMAN's Avatar
bttt
Old Mar 22, 2001 | 07:00 PM
Omar's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 92RSMAN:
what if you have a pull down hatch motor but there is no switch....do you just need a switch?? would like to get that feature for sure.</font>
Yes, all you need is a switch, wiring for it, and a mounting location for it.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Mar 22, 2001 | 09:00 PM
92RSMAN's Avatar
sweet thanks omar! hey is the wiring there? i guess i just need to get my lazy butt out there and take it apart....connections on the assembly? oh well ill check
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
sailtexas186548
Aug 24, 2015 10:11 PM
stalkier
Aug 13, 2015 12:59 PM
