Bottom of door rotted
Old Oct 14, 2012 | 08:57 AM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Is there anyway to repair the bottom of the doors i was thinking of cutting the bottom half of the door out replacing the rotted metal would this way come out cheaper or should i just try to find rust free doors an use those an rubber undercoat the inside an por-15 them as well
Old Oct 14, 2012 | 10:26 AM
splitface454's Avatar
Car: 92 Camaro RS
Engine: Carb'd 355
Transmission: 5 speed
Axle/Gears: 3:42 gears
Re: Bottom of door rotted
How bad are they? Got any pics?
Old Oct 14, 2012 | 12:09 PM
toomany's Avatar
I used patch panels to fix the bottoms of both of my doors. Think they were Sherman brand, bought them through Napa. I didn't think the metal was too thin, just have to take time when welding. After I had the bottoms on I used some fiberglass to seal up from the inside. I left the doors on when I did it, made it a little easier to line it all up before I tacked it on.
I also had to patch behind the mirror on the drivers side.
Old Oct 14, 2012 | 12:36 PM
Engine: LR4 4.8
Ill get pics of it up when i get outta drill weekend with uncle sam i know the passenger side has rot holes the sizes of 25 cent quarters its the drivers side that is really bad can stick my whole hand up with it fully open hand
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Trevor Tarry
Sep 15, 2015 02:04 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
NiG
Sep 7, 2015 11:25 PM
Stryker412
Sep 7, 2015 09:11 AM
