Repaint.......prepping my thirdgen
Old Oct 14, 2012 | 05:14 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
I have a 92 bird that needs some paint and bodywork done. I have 2 new fenders and a formula hood plus and all the tools to do the paint and prep work myself. the bumper needs work and the dent and rust repaired. Other than that I want your opinion on some things........
(Im gonna have the bodyshop fix these)
This is the paint im using. http://www.expresspaint.com/automoti...ic-21p6325.htm
How many quarts of paint does it take?
The clear coat. http://www.expresspaint.com/automoti...rts-2p2176.htm
For the most part the paint is decent. Can I sand down to the primer and reprime? Or can I go just as deep as the basecoat?
Thanks for your opinions and help.
Old Oct 14, 2012 | 07:41 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: Repaint.......prepping my thirdgen
Wow a single quart is $115, that's higher than some pretty high-end and well known paint. I take it that this is some kind of aerosol can method. I'm not saying it won't work, but it will surely be expensive.
My recommendation would be to do all the prep work yourself and find a shop or someone that will rent to you the equipment or spray it for you for a much smaller than normal fee. A really good place to possibly meet someone like this would be your local PPG or other paint shop. Talk to the the people that work there and also hang out and BS with them, you'll meet painters that do this every day and for a living.
If you're going to paint it yourself and this is your first time using this method, then I suggest taking the money that you would have spent on the paint and learn by trial and error using regular liquid paint and an air gun. I think it'll be cheaper and better looking in the end. Start by painting and stripping a single panel until you can do it right the first time. I plan to practice on my project truck by using this very technique. Some people go buy a hood from the local junk yard and practice on that.
Old Oct 14, 2012 | 09:21 PM
Car: 1984 T/A
Engine: LQ4
This is no aerosol can method. Im doing the prep work and paint myself except for what is in the pictures i provided. I did some more digging and found the same paint for 80 a quart. but how much does it take to do a whole car?
Old Oct 14, 2012 | 09:38 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Ok, I'm sorry, I didn't mean to offend you. I hadn't heard of that paint company before and when I did some Googling, the results made it look like they provided a spray can type product so I thought that was how you would be applying it. As for how much, I couldn't tell you for sure. From looking around I've seen anything from 2 to 6 quarts. Now I really doubt it will take 6 quarts, but I doubt that two would really be enough especially if you want multiple coats of base and you paint all the GFX parts separately.
Old Oct 14, 2012 | 10:09 PM
Car: 1984 T/A
Engine: LQ4
Its ok I wasnt offended. I have the spare fenders and formula hood off the car now. can i prep and paint those now or should i wait and do it all at once?
Old Oct 14, 2012 | 10:13 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
wait! too many factors effect the final color, and it's next to impossible to paint all of these parts and make it all match in the end, ESPECIALLY metallic paint
Old Oct 14, 2012 | 10:15 PM
58mark's Avatar
if you are interested in a rather long but detailed thread with lots of tips on painting, read this
https://www.thirdgen.org/forums/memb...on-thread.html
Old Oct 14, 2012 | 10:26 PM
Car: 1984 T/A
Engine: LQ4
ok thanks for the info. can i at least prime the spare parts and wait?
Old Oct 14, 2012 | 10:42 PM
58mark's Avatar
oh yes. Prime and prep them, but you might want to be careful about how long you can wait to spray them with real paint before the adhesion of the primer lowers. you'll probably want to respray them with a primer or sealer right before you put the paint on. At least one coat
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
Exxon Limited
Aug 9, 2015 08:13 PM
