What can I do to prevent rust... ???????
Old Apr 4, 2001 | 08:33 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
my car got hit a month ago.. and it is starting to develop a little rust where the damage is. What should I do to prevent this? I will be getting a paint job sometime this summer, but I dont want to get it covered in rust by then. I plan on keeping this car a loooooong time. Also, I dont want and Bondo on my car at all....
Anyone got any suggestions for me?
http://kiztope.50megs.com
92 Rs 3.1/T-5
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14)
"If it can be better than it is, make it so!" Leon Calrinsky (00)
Old Apr 4, 2001 | 09:41 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Wet sand the area around the rust spots (getting the rust off too of course) with some 320 and put some zinc primer on it (rustolium high zinc will work fine).
If you're finicky about primer spots on your car,,,, get a 6oz can of duplicolor that closely matches the color of the paint now (sold at autozone) or plastikote has lots of available colors too. The good thing about Duplicolor is it's laquer,,, you can rub it out to color blend it to the surrounding area.
Hope that helps ya out some
My Firebird It Lives Again!!(Sorta)
Your Car Here?
Part Diagrams
-It's always the last one
Old Apr 4, 2001 | 09:54 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Pardon my ignorance on this subject, but could you define "Wet sand" ? Thanks!
Old Apr 4, 2001 | 10:02 PM
deadbird's Avatar
Engine: TPI 305/ v6
No biggie,,
Standard papar is like what you get at the hardware store (brown color)
Most auto stores carry paper that has a coating on it to keep it from falling apart when it's wet (paper is black in color)
When you wet sand you want to keep a bucket of water, spray bottle or a hose,,, as long as theres'a a source of clean water.
The water acts as a sorta of,, um,, lubricant,, and keeps the grit from burning off or clogging with paint. Just keep the area you are sanding "clean" with fresh water (not constants but every little bit to wash 'dirt' away).
Mainly just feather out the sharp edges smooth to keep chipping to a minimum and get rid of the rust.
I realize sanding rust with water seems stupid,,, but if the metal is clean & you dry it right after then prime it you won't have a problem. The key is a zinc based primer to keep the rust from spreading. (zinc is what coats the gas tank to keep it from rusting just in case you care to know how well it works)
Old Apr 4, 2001 | 10:44 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Thanks... Ill get that stuff tommorrow...
theshackle
Mar 5, 2017 06:37 PM
djmarch
May 8, 2016 11:32 AM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
BurlyChev
Aug 22, 2015 11:42 AM
Amillionoh7
Aug 7, 2015 01:24 PM
