Convert 1987 T/A into 1982-83?
Old Oct 25, 2012 | 12:04 AM
r0t0rdr1ver's Avatar
Car: 1987 IZ, 1990 IZ, 1992 GTA
Apologies if this has been covered elsewhere. I tried a quick search, but didn't really come up with any definitive answers.
I have some ideas in mind for an early (82-83) trans am project, but am having a hard time tracking down a solid rust free car where I live. I did however find a solid 1987 GTA minus engine/trans for a steal, and am curious if I can bolt on all the 82-83 stuff? Nose, fenders, hood, headlights, etc. I really want the look of the stock 82-83 cars in all respects, and am curious if this can be done relatively easily.
Planning an LS1 6-speed swap also, and am not sure what car may be a better starting point. Any help or input here is most appreciated. Thanks!
Old Oct 25, 2012 | 11:53 AM
steve87ta's Avatar
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
Re: Convert 1987 T/A into 1982-83?
For me anyways, a real gta is more $ than an 82-84. Specaily if it is complete even if the drive train is upgeaded. My 2 cents...
Old Oct 25, 2012 | 12:04 PM
Unfortunately for that car the original drivetrain is long gone, so I don't see much value left in it, unless you could find the missing components and put the car back to original. It will never bring the kind of $$ an unmolested car would. In my mind it's the perfect candidate for a restomod versus modifying an original.
Old Oct 26, 2012 | 08:28 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Yes, all the earlier stuff will fit on it, the chassis is the same.
I believe the first thing you will need as you are building from a bare chassis is the kmember for ls conversion.
Old Oct 26, 2012 | 01:12 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Plenty of people have converted later cars to 82 style (mostly for Knight Rider clones). Everything bolts up to a certain degree, but it's a LOT of work if you're going to do it right, as I don't think 82-84's share any interior pieces at all with the 85-92 cars. If you just want to do the body though, it shouldn't be that bad.
Old Oct 26, 2012 | 02:44 PM
Thanks for the responses guys, much appreciated. Not overly concerned about the interior so much as the exterior stuff. Not going for a 'clone', but an early third gen T/A restomod with a twist
TX-SleeperC5
Feb 24, 2016 01:34 PM
89fast5oh
Sep 8, 2015 09:55 AM
scottmoyer
Sep 7, 2015 07:06 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
