button not working on overhead console
Old Apr 6, 2001 | 05:36 PM
CamaroZ_85's Avatar
i just took it out of my parts car...only one button worked (dont remember which) but it turned on the map light...i believe the other is supposed to turn on the interior lights, right?? also, how does it turn these lights on???? does it just power the dome light, which is on the same wire as the rest of the lights, which in turn powers the others???? thats the only way i can figure..also i think the only other lights are by the 2 kick panels, right? those dont work on my car ill have to check it out...but any suggestions appreciated on the switch....thanks
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
Old Apr 6, 2001 | 08:59 PM
MNformula350's Avatar
Well in the car a overhead console comes in originally that buttom turns on the interior lightsIncluding the dome light.
But when i installed one out of a 86 Firebird in my 90 Formula,that button only turns on the dome light,but when i use the headlight switch to turn on the interior lights all hte lights come on Domelight,light in trunk and the floor lights.
So i may have hooked it up wrong or some thing but it works well enough for me
And it just looks cool too!
84 FIREBIRD-(undergoing rebuild)2.8 V6,5spd,T-Top
90 Formula Modded 350 TPI T-Top
WANTED:82-84 Firebird 2.5 4cyl,4spd-Just Cause
Previous 3rd gen's
83 Trans-Am 305 CFI auto T-TOP
84 Firebird 305 H.O. auto HARDTOP
87 Firebird 2.8 V-6 auto HARDTOP
Old Apr 7, 2001 | 11:38 AM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
I took the time to wire my lights in my overhead into the wires for the doorswitch that activates the lights when opened.
I can't remember exactly how, but if you draw it out and figure when you want the electrons to flow (holes flow for others) you should be able to figure it out.
Just what I did...(oh yeah..my map light mirror too )
Old Apr 8, 2001 | 02:26 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
You checked all your grounds, and actual connections at the switches yet?
Old Apr 8, 2001 | 10:41 PM
87 Firebird's Avatar
In my 87 bird with factory installed overhead console, the dome light powers JUST the dome light. The wheel that adjusts guage dimness will turn on everything.
Old Apr 9, 2001 | 12:57 PM
RenoLB8's Avatar
Your wirings fine, just about everyone I know says the same, the pass. button only turns on the domelight, but also everyone says the pass. button seem to get sticky eventually. Try disaassembly and claning. I just leave it alone and use the dimmer wheel myself.
Related: nyone have a "Firebird" flashlight in their Camaro overhead console? If so, I have the opposite problem. Email me.
-Reno
reno9114@aol.com
'88 Firebird LB8
"Cerberus"
-Supercharged Hybrid LB8/L32 Project-
"Got a green light, got a red light, no cop, no stop, man I don't care, every one of you could be the same, every one of you could play this game, got a green light, got a green light but you're going nowhere..."
http://www.angelfire.com/il/Firebird28/index.html
1992 Trans Am
May 10, 2023 07:19 PM
Casey Meyers
Mar 2, 2016 10:46 AM
The_Phoenix
Feb 4, 2016 07:10 AM
TheJoeY88
Aug 13, 2015 06:51 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
