How do you remove the doors on a 92 Z28?
Old Oct 30, 2012 | 03:01 PM
CGMorrison's Avatar
Car: 1992 Z28
Engine: 355
Everything I have read says to just unbolt the hinges. I can't figure out how I'm supposed to unbolt the lower hinge. Only one of three bolts on the lower hinge has a bolt on it and I can't figure out how to get to it with the pin that is in the way. Any help would be greatly appreciated.
Old Oct 30, 2012 | 08:57 PM
toomany's Avatar
Re: How do you remove the doors on a 92 Z28?
Two of the three bolts on the lower hinge come from the inside of the car. If you remove the kick panels you will see them. Sometimes there is a rubber/tar patch over the access hole.
Old Oct 30, 2012 | 09:16 PM
CGMorrison's Avatar
Car: 1992 Z28
Engine: 355
My wife looked at it and pretty much told me the same thing you did. Thank you, though. I felt kike a retard after she showed me. It was pretty obvious the bolts were facing the other direction.
Old Nov 27, 2012 | 09:42 PM
Ashton89iroc's Avatar
Car: 1987 IROC-Z
Engine: Vortec 350 crate #12530282
Transmission: 700-r4 Auto
haha, don't feel so bad. same thing happened to me the first time i swapped doors. i sat there for a day kicking tires thinking "what the heck!?!?"
Old Nov 28, 2012 | 12:18 AM
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
We're Bright & Smart that we can figure things out its just that we are usually thinking other things and are preoccupied with other problems that we sometimes have the light bulb switch turned off.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
3rdgenparts
Aug 8, 2015 07:09 PM
