power antenna install
Old Mar 10, 2001 | 12:53 PM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
my car came with the stationary antenna. Dis any camaro come with a power one? what is invovled in the install??
not looking for stealth just a cleaner look.
Old Mar 10, 2001 | 03:39 PM
JPrevost's Avatar
Car: 91 Red Sled
I installed a power antenna. It is a PITA. I had to cut metal and bend it to make room for the whole unit. If I had to do it again I would get one of those remote motor ones. If you get the one with the motor on it trust me, you'll need to do some metal cutting, no way around it. If you don't mind cutting metal then remove the front tire and the plastic inner fender to make it a little easier.
, Jon (91 RS too many mods to list)
Old Mar 10, 2001 | 06:33 PM
Car: 86 Z28
Axle/Gears: TBD
hmmm. where would i get the antenna with the remote motor?
[This message has been edited by redcamaro83 (edited March 10, 2001).]
Old Mar 11, 2001 | 02:30 AM
Omar's Avatar
I also had to cut metal away for my power antenna, but this is only true if you go aftermarket. GM sells power antennas for our cars that dont require any fabrication. The motor is mounted really low so it will fit. The only prob is that they only come in chrome. I wanted a black one.
1989 IROC-Z 5.7L
Old Mar 11, 2001 | 08:17 AM
Car: 86 Z28
Axle/Gears: TBD
Anyone got a part number for either antenna?
location??somthing...
Old Mar 11, 2001 | 10:22 AM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
gmpartsdirect.com 22101888 $74.54 If your using the stock head unit. Check to see if a plug in the back for the power antenna. Also you will need relay if using the stock antenna.
Old Mar 14, 2001 | 11:59 PM
Car: 86 Z28
Axle/Gears: TBD
sorry double post
[This message has been edited by redcamaro83 (edited March 14, 2001).]
Old Mar 15, 2001 | 12:03 AM
Car: 86 Z28
Axle/Gears: TBD
got the antennas boys...
#1 AM/FM POWER ANTENNAS For all vehicles with limited mounting space.
http://www.jcwhitney.com/product.jhtml?CATID=4964
#2 AM/FM POWER ANTENNA Fully automatic, remote-mount motor.
http://www.jcwhitney.com/product.jhtml?CATID=4976
#3 AM/FM POWER ANTENNAS Fully automatic—raise and lower with a flick of your radio dial!
http://www.jcwhitney.com/product.jhtml?CATID=4977
"Work like you don't need the money, love like you've never been hurt, and dance like you do when nobody's watching."
Old Mar 15, 2001 | 09:06 AM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Those antennaes look pretty good. Has anyone installed them on their cars? I think that would be a pretty easy mod to do. A power antennae would deffinitely clean up the look of the car.
Houston f-body Member Page
Third Gen Project (New Site)
1989 305 tbi Camaro RS Red/Red
Ram Air II Hood
Centerline Champ 500 Rims
Edelbrock Open Element
MacEwen White Faced Guages
"Stock?! Theres nothing "stock" about a stock car."
Old Mar 15, 2001 | 12:08 PM
Vortex_89rs's Avatar
I think some of the GTA's came with power antennas. I always thought it would be nice to have one, but it looked like a pain to install. I looked in the Classic Industries catalog, and they have a little antenna that just sits where you put it. It looks about the size of the cigarette lighter (?) and just has a cable going to it from the radio. I think it was around $60 or so. If anyone has tried this, how well does it work? I think any f-body would look better minus the antenna sticking up. Might even gain .000000003 seconds on your ET due to better aerodynamics!
Vman
1969 Camaro Sport Coupe
383, 700R4, leather, everything black but the lights
Previous owner of an 89 RS Camaro
2.8L V6, 700R4
Old Mar 15, 2001 | 02:01 PM
Tony86TA's Avatar
Just orderd the whole assembly last night through gmpartsdirect.com. This was to replace the one in my 88GTA. The # was 22048583, cost was $46.59. I verified this part # though 3 different places, gmprts emailed me the same #. Hope its right. Replaced once in an 86 awhile back. Piece of cake one you get the wheel and inside plastic fender off. Hint, before you start, buy some extra plastic fasteners for the plastic inside fender (tend to break).
Old Mar 15, 2001 | 04:38 PM
Car: 86 Z28
Axle/Gears: TBD
where do i get the plasti clips??
[This message has been edited by redcamaro83 (edited March 15, 2001).]
Old Mar 15, 2001 | 06:10 PM
jobryan26's Avatar
Tony is that a power antenna you ordered? I need to replaced mine.
'87 Trans Am
305 TPI:
160 Degree Thermostat
TB Bypass
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Platinium Plugs
Custom Ram Air with K&N
Old Mar 15, 2001 | 09:44 PM
Tony86TA's Avatar
Yes, I should recieve it by aleast the middle of next week. I will repost when I recieve, to confirm. You can get the plastic rivet like things from the dealer.
Old Mar 15, 2001 | 10:55 PM
jobryan26's Avatar
Does that require running the antenna wire and etc. through the firewall and misc. or does the cable and wires disconnect at the antenna for a swap over?
'87 Trans Am
305 TPI:
TB Bypass
Accel Super Coil
Old Mar 16, 2001 | 12:36 PM
Car: 86 Z28
Axle/Gears: TBD
Yes does the install require me to go run wires through the firewall?
Old Mar 16, 2001 | 08:54 PM
Tony86TA's Avatar
The wires from the factory run through the side kick panel. There is also a relay mounted behind the knee trim on the pass side. Thats all I know about it.
Old Mar 16, 2001 | 09:39 PM
Car: 86 Z28
Axle/Gears: TBD
any idea what the relay is for? anyone???
[This message has been edited by redcamaro83 (edited March 16, 2001).]
Old Mar 19, 2001 | 11:04 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep, the relay's for turning on the power antenna. Factory setups had one pink wire going to the radio, when that wire got +12 volts, it turned on the relay. The relay has two three-pin connectors on it. One is the "radio side", with the pink wire, and a wire to ground. The other side has three wires (this is by memory, so...) white, green, and gray. One shoots over to the fuse block to get power. The other two go to the power antenna.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 19, 2001 | 12:38 PM
Car: 86 Z28
Axle/Gears: TBD
anyone know the approximate mounting depth that is available below the antenna hole without cutting?? I haven't taken the fender off yet(i'm replacing it).
Old Mar 20, 2001 | 11:06 AM
MariahFan's Avatar
Car: 86 Z28
Engine: '76 305 0.030 over
As an aside, has anyone ever checked into installing a window mount antenna? I once had a 77 Impala that had the antenna embedded into the windshield and a lot of GM's cars (Grand Prix, Intrigue, etc.) come with antennas embedded within the rear window (looks like part of the rear window defrost system, hardly notice they're there). In my experience, these antennas seem to have much superior reception in comparison to the shaft units and you never have to worry about them getting broken off.
Old Mar 20, 2001 | 11:09 PM
Car: 86 Z28
Axle/Gears: TBD
its an idea. anyone done it??
[This message has been edited by redcamaro83 (edited March 20, 2001).]
Old Mar 22, 2001 | 09:37 PM
Tony86TA's Avatar
Update on that ant assembly I ordered. That part # was for the mast only. Three different dealerships gave me that same #. Waiting for a response from gmparts on correct # so I can return and get this job finished. Need to find a parts # book or something. :
Old Mar 22, 2001 | 10:26 PM
82Zee28's Avatar
Very odd. I did not have to cut any metal when I replaced my power antenna. I bought a used one at a Pull A Part for $10 and went thru the kick panel and wheel well without having to cut any metal at all.
Old Mar 23, 2001 | 05:44 AM
cbpldc's Avatar
The problem with having it in the rear defrost is that whenever you turn on your rear defrost, your radio reception is diminished. That is just my experience with a friend's Grand Prix. To have it done you would need a custom made hatch glass, and I can't even imagine how much that would cost.
Chris
Old Mar 30, 2001 | 12:22 AM
valu8or's Avatar
Any luck with ordering the antenna? Anyone have a p/n for the whole assembly?
Old Mar 30, 2001 | 12:34 AM
JPrevost's Avatar
Car: 91 Red Sled
I don't have a part number but I did have to cut metal to get the motor to mount. Wires weren't the problem, just the tip top of the motor. If it had a lonter shaft then it would have worked no prob. I'm thinking if it's $50 for just the shaft then it's going to be over $150 for the whole unit. GM always screws us like that, oh well. Just get the remote mounted motor and there will be no problems.
, Jon (350 TBI!)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)
  • Holley 670 TB unit w/ 1/2" spacer/adapter
  • Edelbrock RPM vortec intake
  • 350ho 330hp vortec crate motor
  • 8" harm. balancer
  • Stewart stage 2 water pump w/160 thermo
  • SLP tri-y headers to full 3"
  • Rebuilt trans w/ SLP shift kit
  • Centerline 16x8's all around
  • 36/24 mm sway bars
  • Full poly bushings, even motor mounts
  • SLP LCA and panhard
  • Alston SFCs
  • Edelbrock 3 point STB
  • Global west steering brace aka wonderbar
  • Eibach pro kit springs
  • Bilstien high perf. struts and shocks
  • All this and I still have AC
My websiteAny questions?
Old Apr 5, 2001 | 08:39 PM
Tony86TA's Avatar
Ok guys, Finished install today. Forgot how clean it looked with the antenna down. Correct # for complete antenna with motor is #22062580. You will also need to order a bracket #22038182. Gmpartsdirect.com. Parts plus shipping and handling came to $120.26.
Old Apr 5, 2001 | 08:47 PM
valu8or's Avatar
Tony, You are the MAN!!!! I have been searching for this part number for a long time and all the people with parts interchange books have not helped out at all (as you already know). I am ordering my new one today!!! Thanks.
Old Apr 10, 2001 | 11:49 PM
Lonster's Avatar
I had been looking to install a power antenna until I read a post the other day about an "invisible" antenna sold by Radio Shack for about $4.99. Several people have tried it out and it seems to work great. The antenna is basically a thin wire that is applied along the edge of the windshield where it is practically unnoticeable.
Those who have used it say they get great reception in both AM and FM. I think it is worth consideration especially when looking at the difference in price and installation time. Someone said it only took a half-hour.
You can see it at Radio Shack's site at: http://www.radioshack.com/product.as...5Fid=12%2D1325
If that doesn't work, the product number is 12-1325
Admittantly, I would like to do the power install just because I like gadgets and was planning to put in a semi-automatic antenna with a switch but I like the low cost of the "invisible" type.
Hope this is of some use.
Old Apr 12, 2001 | 01:51 AM
jobryan26's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Tony86TA:
Ok guys, Finished install today. Forgot how clean it looked with the antenna down. Correct # for complete antenna with motor is #22062580. You will also need to order a bracket #22038182. Gmpartsdirect.com. Parts plus shipping and handling came to $120.26.</font>
Tony how did the install go? Have to cut anything? details please! Thanks Man
'87 Trans Am:
(Engine)
305 TPI
180 Degree Thermostat
JET Fan Switch
TB Bypass
Accel Super Coil
Removed Emissions Equipment & Cat.
(Stereo)
Full Kenwood Excelon System
Old Apr 12, 2001 | 10:34 PM
Tony86TA's Avatar
Easy install. Only thing you have to cut is three wires. Cut them close to the old antenna so you have enough wire to work with when you splice them into the harness on the new one. Make sure you soder the splices. If you don't have a sodering gun, get the shrink tube wire connecters with the soder in them. It is a tight fit, however the fender does not need to be messed with. Just take your time and work it out of the fender area. Once wiring is spliced, check to make sure it works before installing. Also before putting inner fender piece back on, check to make sure antenna extends out of the top of the fender straight. Can be adjusted some on lower bracket. By the way, you don't have to disconnect the battery, just unplug the antenna harness from relay behind the pass. side knee trim panel. Also make sure you buy some replacement plastic fasteners before starting to reattach plastic inside fender piece to your fender. Any auto parts store will have them. 1 1/2 - 2 hour job MAX.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
