EXPERT REPAIR ADVICE NEEDED
Old Apr 11, 2001 | 10:05 PM
darbster's Avatar
I own a mauii blue 88 camaro sc.I recently got into a fender-bender which seriously messed up the paint on the front bumper.on about three spots the bare "metal" on the bumper is showing.on the rest of the bumper the paint is flaking off but there is another coat of paint underneath.
*ANYWAYS* HERES MY QUESTION...
I was told that i would need a new bumper because a new paint job would not last for more than a year on my damaged one...IS THIS TRUE? IS THERE NO WAY TO SAVE IT? I would also like to know the process-materials needed to repaint it.Any help is greatly appreciated.
Old Apr 12, 2001 | 11:43 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
If it is painted right, with the flex additive mixed right, it should stay on there, if not it will have to keep getting repainted.
Old Apr 13, 2001 | 12:19 AM
Blue502's Avatar
One thing to consider is if there were any stretch marks or creases made in the urethane. If there are, they are all but impossible to remove, and a new cover would be much cheaper in the long run. Even the cost of just refinishing your original may exceed the cost of replacement. Something to consider.
If you decide to save your cover and do the work yourself, purchase some SEM flexible parts stripper and remove all of the old paint. SEM also makes a flexible filler that basicallly works like bondo (but is much harder to sand out). I used some of that to shave my front emblem off the nose. You MUST use flex agent if you want the paint to survive, but beware that it will cause the new paint to vary slightly in color from the rest of the car.
[This message has been edited by Blue502 (edited April 12, 2001).]
Old Apr 13, 2001 | 10:52 AM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
i know the feelin i have to replace the front and rear bumper covers on mine cause of stress marks,
IROCZ1989
Jan 24, 2016 03:55 PM
dutch930
Sep 11, 2015 06:58 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
