How do I remove hood insulation
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
I need to remove the insulation under my hood so I can get the louvers out for painting. How do I get it apart without destroying the retainers or the insulation? Should I use something like a trim panel removal tool?
Re: How do I remove hood insulation
I used panel clip pliers from Harbor Freight, http://bit.ly/Rw4Qy5, and they work great for both door panels and the hood clips. Unless your insulation is in great condition, I would replace it. Mine was nothing more than a fire hazard so it had to go. I bought new hood and door clips at Ace Hardware. Do not remember how much they cost, but they were a lot cheaper than at the auto parts store.
Hope this helps.
Hope this helps.
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Were the replacement retainers exact matches? My car is very original and I really want to keep it that way.
Engine: 4++,350 & 305 CIs
I used a gentle pulling and twisting motion to remove the clips then put them in my old dishwasher that I use for cleaning plastic parts. (works great for old mouse filled duct work)
Not sure if they are an exact match, but they seem to be pretty standard. However, if you want to find exact clips for your car, I suggest you check: http://www.clipsandfasteners.com/Gen...eners_s/64.htm
They seem to have anything and everything clip-related, and their prices are more than reasonable.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
