Hinge pin / bushing lower driver door
Old Nov 9, 2012 | 12:08 PM
CamaroLover69's Avatar
Car: 1991 Camaro RS
Engine: 5.0L V8 TBI
Transmission: MX0
My driver door is sagging and tough to close. I see this hinge looks terrible and wondered how likely it is that this could be the entire issue? I can close the door with upward force. It is scraping the ground effects to the rear of the door only.
Attached Thumbnails Hinge pin / bushing lower driver door-lower-hinge-91-camaro
Old Nov 9, 2012 | 03:05 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Hinge pin / bushing lower driver door
Yes IMO that would be a good place to start your door repair.
Old Nov 9, 2012 | 03:37 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Hawks makes a replacement pin kit or around $80. Check it out.
Old Nov 9, 2012 | 04:24 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Its not the entire problem. That is the detent roller, it basically holds the door open so it doesnt come back and hit you when you get out.
You will need to replace (1) detent roller (2) lower hinge bushings (1) lower pin (2) upper hinge bushings (1) door striker, per door.
The lower bushings generally come with the pin. The lower pin (new) will probably be loose in the bores because more than likely they have enlogated over the years. If this is the case, the pin remains stationary in the bores and can be welded in place.
There is a greasable option (upgrade) for the upper hinge bushings available.
http://www.chevyhiperformance.com/te..._chevy_camaro/
Parts are available at
http://www.top-downsolutions.com/Bod...y-and-Interior
Detent roller info
https://www.thirdgen.org/forums/body...oller-pin.html
Old Nov 12, 2012 | 04:22 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Have someone help you with the diagnosis of the door hinges. Have them grab hold of the bottom of the open door and lift, then release it while you closely inspect the upper and lower hinge pins with a flashlight. If you see movement in just the lower pin and bushings, then the job is much less expensive. If you see movement in upper pins and bushings, then they too will need to be replaced.
Lon
Old Nov 12, 2012 | 08:38 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Detent roller info
The detent roller and the pin that goes along with it are about $13 from GM. I bought one yesterday lol
Old Nov 14, 2012 | 03:44 PM
1Aauto's Avatar
Former Sponsor
We now carry a nice door pin and roller kit on our website. Here's a link to them. http://www.1aauto.com/1A/DoorHingePi...ampaign=1ATony
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Apr 9, 2016 10:20 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
chevyguy1999
Aug 16, 2015 08:49 PM
