My little project
Old Nov 11, 2012 | 12:22 AM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
My little project
This will be the second time Ive done this I had a few kinks in the last one I made but as requested by lmancha96 Ive decided to do a build thread for it. To start youll need a something to "pop" the door open I used a clicker from my old entertainment center's door(You can use anything you want). Once you decide how to make it pop your ready to dig in youll have to remove the cap and the gas nozzle plate piece.
Easiest part is to shave the the finger notch out(I used a dremel)
DO NOT REMOVE THE GUIDE IT KEEPS THE DOOR ALIGNED
Next is to drill the hole to mount the the clicker
After drilling it youll need to heat up the spot where you drilled (keeps the screw from going to far and making it a pain to reinstall everything also doesnt leave a gap between the clicker and the nozzle plate)
One screw will not hold it in place so once you have it in place superglue it(make sure its in place before you do) dont worry about the discoloration Im repainting it when done
Then use fiberglass filler to fill in for strength/structure, then bondo over that to get a smooth finish
Oh and make sure the striker plate is in the right place glue it in
Prep,primer,paint,install and enjoy
Old Nov 11, 2012 | 08:59 AM
MYFIRSTZ's Avatar
Car: 1987 IROC-Z all stock (sold)
Engine: 1987 T/A (current project)
Re: My little project
cool idea. looks like you did a nice job with it.
Old Nov 11, 2012 | 10:08 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
i did it a little different i cut out the stop on the ring then plastic welded the popper into place. i liked your idea when you did it the first time
Old Nov 11, 2012 | 10:56 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
I did it the same way as the first time? only difference is last time i had alignment issues I had to lift the cap onto the popper and then close it which was a pain this time i can just close it and push it in and it works great
Old Nov 11, 2012 | 11:23 PM
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 5 speed manuel
Axle/Gears: 3.08
Like your idea
Old Nov 11, 2012 | 11:28 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Originally Posted by arod231
Like your idea
Thanks Guys
Old Nov 12, 2012 | 01:35 AM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
my mistake you did change it looks good got rid of the finger notch sticking out thats whats important :P
mattcanty
Oct 12, 2015 11:08 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
92projectcamaro
Sep 29, 2015 07:07 PM
Vincent135
Sep 28, 2015 10:50 PM
