Painting my car,
Car: 86 firebird
Transmission: Th350
Axle/Gears: 3.48
Painting my car,
hey i have painted many thigns before, but first time doing painting that requires hardner and whatnot. i am going to be using Vipre blue pearl on gray primer. what are the Ratios going to need to be? i need as much info as possible on painting this thing BESIDES hearing the words "get it painted by someone". thank you
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
Re: Painting my car,
Get a tech data sheet from the manufacter on mixing ratios.
Pearls can be tough, try a 75% overlap instead of 50.
Its only paint, you can do it over again if you screw it up,, but that gets expensive.
Try to spray it all at once and walk the car so it stays uniform.
Good luck.
Good luck.
kah992
Aug 19, 2015 02:55 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
