Headliner (Help)
Yes you can fix it or replace it. Many aftermarket companies offer plastic or covered headliners for a fairly affordable price. Replacing it takes some time and patience but it can be done. You have to take down the entire headliner board after removing several plastic pieces. After you pull it out inspect the headliner material and see if it can be reused or needs to be replaced. If it is in bad shape try a fabric store they usually have the same material. Using 3M spray adhesive reapply the material back onto the board. T-tops, however are a different situation. Replacing the material is much more difficult. It's really a judgement call, whatever you feel comfortable doing. Good luck!
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
