How to repair hood louvers with cracks or holes
Old Nov 24, 2012 | 10:13 PM
1986Iroczmark's Avatar
Car: 1986 Iroc Z28 Camaro
Engine: carbed 5.7 liter 350
Transmission: th350
Ok heres my hood louver that got a hole in it and this is how to repair it.
First I used http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_x_7160098-P_x_x?cm_mmc=ACQ-_-Google-_-enhancedRM-_-7160098&ci_src=17588969&ci_sku=7160098&ci_gpa=pla&ci_kw={keyword}&gclid=CMr2tISf6bMCFQWonQodwDoArA#utm_source=acq&utm_medium=google&utm_campaign=enhancedrm&utm_content=7160098
mix the permatex then spread it on the crack or hole
( try not to leave to much excess because it will be more work later to sand that off.
wait around 20-30 mins until its dry and hardened and then sand.
sand until flat
and then paint
This is what i used
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_x_7141216-P_x_x?cm_mmc=ACQ-_-Google-_-enhancedRM-_-7141216&ci_src=17588969&ci_sku=7141216&ci_gpa=pla&ci_kw={keyword}&gclid=CK_3nqOg6bMCFbKiPAod4B0AUQ
and bam it's fixed
Not perfect but much better.
Old Nov 24, 2012 | 10:14 PM
Transmission: th350
Re: How to repair hood louvers with cracks or holes
Oh and i forgot to add when sanding start by using a low grit sandpaper to get the excess epoxy off and then use a high grit to smooth.
Old Nov 27, 2012 | 09:30 PM
Ashton89iroc's Avatar
Car: 1987 IROC-Z
Engine: Vortec 350 crate #12530282
Transmission: 700-r4 Auto
awesome! I've been looking for a fix like this, i have a small BB sized hole in mine. now i just need to find way to fix broken mounting pegs...hmmmm
Old Nov 29, 2012 | 05:45 PM
Transmission: th350
Yeah I have a lot of broken pegs too i'm gonna find out a way to fix it somehow.
Old Nov 29, 2012 | 05:56 PM
Car: 1987 IROC-Z
i thought of something. as long as at least half the peg is still connected. you can get a small screw with a spacer and a washer to hold it in place. it should work just fine, and you won't have to worry about it breaking.
Old Nov 29, 2012 | 07:37 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
You can make the pegs out of the permatex too. Use tape or wax paper to make little molds. I've done this with the firebird dash speaker covers.
Frozer!!!
Jan 19, 2024 04:55 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
hydrolic144
Sep 4, 2015 09:48 PM
tc7761
Aug 30, 2015 09:45 AM
LittleFranks
Aug 20, 2015 03:55 PM
