softer shocks??
Old Apr 29, 2001 | 10:44 AM
Andrew H's Avatar
softer shocks??
I have an imported 87 formula with the performance suspension option. I live in England & most of the roads I drive on are not that smooth and the ride can be very harsh.
Does anyone know of any shocks that I could change to that are suitable for this car that will make a noticeable improvement in ride quality -I'm looking for a slightly softer ride (but with nothing more than a minor effect on handling)
I'm not looking to spend a huge amount of money, but any help would be appreciated!!
thanks!
Andrew
Old Apr 29, 2001 | 03:32 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Softer shocks really won't help. The f-bodies already have relatively soft shocks. The springs are what make the cars so unbearably stiff.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Apr 30, 2001 | 07:56 AM
purpleworm's Avatar
I have said it before, They handle like a train but ride like a dump truck. I found the biggest improvement was getting rid of the gas rear shocks and putting on GM factory hydralic shocks. Night and day difference in handleing and smoothness. I would go with a good quality front gas shock though. Maybe KYB or something.
91 Z28 Camaro
305 TPI
Flowmaster 3" exhaust
700R4 with 2000 Stall and shift kit
One sweet sounding system
Old Apr 30, 2001 | 09:48 AM
cbpldc's Avatar
Another suggestion might be to check your bushings. You may have worn out ones or poly bushings. Try to find new rubber ones like the ones that came from the factory.
Chris
Old Apr 30, 2001 | 12:54 PM
Andrew H's Avatar
thanks for all your suggestions -really useful! -I'm gonna check the bushings first and go from there and might consider the hydraulic shocks
Old May 1, 2001 | 08:42 PM
gregz28's Avatar
Ive been living in Europe for a while, and just installed the custom valved shocks and struts from tpis.com. The differance on the tight an rough roads as well as at high speeds on the Autobahn is a million times better. I wish I had installed them earlier! Check out our F-Body Europe site and leave a post in the thirdgen forum if you are interested in joining.
91 black Z28 305 TPI
Plans for 383...
Jet-coated TES headers,
Flowmaster cat-back,
SLP cam (206/212@.050), Cloyes double roller timing chain, TPIS shocks/struts, TPIS STB, adj. fuel press. regulator (47psi), 170 stat, B&M shift kit, BMR 1.5" springs, Ed Wright custom chip, gutted air box, K&N cone filter, Mac Ewen white face overlays
3rdgeners in Europe: CLICK BELOW!
www.fbodyeurope.com
[This message has been edited by gregz28 (edited May 01, 2001).]
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
