need some help on this one!!!!!
Old May 7, 2001 | 05:54 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
how do u get to the rear taillights to change the bulb.i can't figure out how to get to the them to you go from the inside?
and help would be appericate
86 Z28:
350 vette
aluminum heads
T-5
235/60R15 BFgoodriches
dual 3"flowmaster exhaust
20% tint
hatch wing
2 12"kicker solos
300 watt Sony xplod amp
Sony xplod deck
K&N air filter
Old May 7, 2001 | 06:14 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Take the inside trim off that covers the hatch latch/lock.
Unscrew the black plasctic wingnuts (some hidden under spare tire cover & rear compartment trim)
Then pull the lights out
-Welders get better penetration
Old May 7, 2001 | 06:15 PM
Camarogofast's Avatar
You have to take out all the plastic trim pieces in the trunk area. Once you have that off, you'll see a bunch of plastic "wing" nuts. Unscrew the ones that corrispond with the light you want to take off. Then the light assembly comes off from the outside. There will be 3 main light plugs. Pull out the one that you want to replace and then reverse the procedure. It's very simple. Should take 5 minutes at the most!!!
Patrick
Deadbird beat me too it. Sorry!!!
1989 Camaro RS
No Mods Yet, many to come
Check out my web page:
http://members.tripod.com/89camarors
[This message has been edited by Camarogofast (edited May 07, 2001).]
Old May 7, 2001 | 06:42 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
thanx a lot for the help. just one question do i take off the main piece that covers the hatch motor like the whole back piece?
86 Z28:
350 vette
aluminum heads
T-5
20% tint
hatch wing
2 12"kicker solos
Sony xplod deck
K&N air filter
Old May 7, 2001 | 06:59 PM
deadbird's Avatar
Engine: TPI 305/ v6
You are correct sir
