Changing bulbs in air control module???
Old May 2, 2001 | 12:56 PM
Apone's Avatar
Car: 1991 GTA
I would like to replace the lights that illuminate my air vent/temp control module(it is the thing that sits above the radio, I dont know what they are called).
My question is, are you able to do this, or is the module completely sealed and not accessible? It seems like there are two lights that backlight the module, one on either side. My driver side one is almost out, at night when I am driving there is barely any light coming from the driver's side, and seeing as the passenger's side is much brighter it looks like crap.
Has anybody done this? Thanks in advance...
Old May 2, 2001 | 01:22 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
There is only one bulb in that system... Take the torx screws out of the radio trim plate, then you will see the screws for the A/C control head itself. They're metric, 7mm, I think. It's a pain to get to sometimes, but you will see the bulb housing on the upper left part of the backside of that control head. The socket is a twist-n-lock type of thing - just turn it about a 1/4 turn and there you go. Replace the bulb and put it all back together...
KAM
Old May 2, 2001 | 01:34 PM
Apone's Avatar
Car: 1991 GTA
Thanks Thunderstick!
Old May 2, 2001 | 02:26 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
At best that light will be dim--actually, there's probably nothing wrong with it at all. You might consider, as I did, replacing the cluster and AC/Heater control head lights with xenon bulbs from McEwen. Big difference.
JamesC
[This message has been edited by JamesC (edited May 02, 2001).]
Old May 3, 2001 | 04:09 AM
Jza's Avatar
Jza
And just so you know the name next time it's the HVAC control panel. (pretty much what you said)
Old May 7, 2001 | 07:42 PM
David M's Avatar
Car: '84 Z28
Engine: L69
And the bulb is a #194.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 19, 2015 01:36 PM
