Hatch pulldown motor
Old Apr 29, 2001 | 08:19 PM
25thRS's Avatar
Had a weird problem with my hatch tonight. I was just heading out of town on business when I loaded the car and closed the hatch. When I got in, I could hear a kind of "grr grr gr gr grrrrrr" noise. The hatch closed, but it was like the motor wouldn't shut off. Not the sound of a relay clicking or really of a motor running.
Had to leave on business, so I just headed out. Ammeter looked fine and no probs on a 200 mile ride. When I got where I was going it had stopped.
Any ideas?
Maroon '92 RS 3.1L AT PW PDL CC Tilt
Old Apr 29, 2001 | 09:39 PM
stephenc's Avatar
i had this happen to me a while back.
mounting tabs for the plastic pulldown motor assembly had cracked. this assembly houses the motor and gears. the broken mounting tabs caused the entire assembly to be mis-aligned. i tried using plastic solvent to repair the mounting tabs, but they would break again in a few weeks. a replacement from GM was $34.
stephen - 89 GTA
Old Apr 30, 2001 | 07:50 AM
purpleworm's Avatar
Same thing happend to me. When I bought the car the moron just took out the fuse and none of the power options worked. After fixing the cig lighter and plugging in fuses I found that it wouldn't shut off so i just unplugged the motor and use it like a normal trunk.
91 Z28 Camaro
305 TPI
Flowmaster 3" exhaust
700R4 with 2000 Stall and shift kit
One sweet sounding system
Old May 1, 2001 | 09:47 PM
25thRS's Avatar
Thanks, guys.
Problem hasn't repeated, but Stephen's suggestion about the tabs makes sense. I'll check that out.
Old May 7, 2001 | 10:27 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The plastic motor mount is cracked and broken. It can be repaired. If it has just cracked you can epoxy a sheet of aluminum to it and wrap the aluminum around the sides of the plastic. If completely broken you need to epoxy a piece of steel in the broken out section, drill and re-tap. I've repaired them both ways. It's just easier to do it if it hasn't completely broken away yet. Good luck, Lon.
90 RS Convertible
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
zayne0
Aug 24, 2015 07:22 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
1nastygta
Aug 8, 2015 07:38 PM
