hot air blowing on feet!
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
Does everyones 3rd gen car blow hot air on thier feet when driving? My car has always done this. When at speed, it feels like it comes from the motor compartment. At a stop, no air on feet. Is a door open that is controlled by a vacuum source. HMMM?
89 iroc,zz4/700r4/3:70 gears/koni yellows/herb adams bars/and alot of other crap to make it work!
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I believe all cars do that (except the hot part) to keep fresh air moving thru the cabin. Every car I've had/been in does that
-Welders get better penetration
Here is an exerpt from the 89 owner's manual page 2C-7:
"Your Camaro has a flow through venteliation system that provides a supply of outside "ram" air into the car when it is moving. When the vehicle is not in motion you can get a steady flow of outside air into the car with the heater or air conditioning blower running."
That was the caption of a pic of the car with arrows showing the airflow coming in (you guessed it) by your feet, and going through the car and out through the vents in the door jambs.
So that should take care of your question.
Engine: zz4
Transmission: t56
THANKS EVERYONE. I THOUGHT MY IROC WAS JUST UP TO ITS USUAL TRICKERY! ALTHOUGH IT WOULD BE NICE IF THE AIR WAS COOLER.
A lot of manufactures employ this into their vehicles. The air usually comes through the main vents in the dash and not into the foot wells as our F-bodies do.
British Columbia Enthusiast
1989 Formula 305 TBI
Car: 88 Firebird WS6
Possibly a stuck or worn out or removed/bypassed heater valve?
If you leave it all the way in the cool position and turn the fan on... say heat.... the air shouldn't be too warm or the above prob or something with the heater door.
Ghettobird52
Jul 5, 2024 11:18 PM
mustangman65_79
Aug 11, 2015 03:17 PM
