Air coming in to passenger compartment with vent OFF
Old Aug 30, 2015 | 09:34 AM
Todd84Z's Avatar
Car: 1984 Z28
Engine: 305 HO
OK...so I got my car about 3 years ago and although it runs and looks great, obviously there are many things that require attention on a 30 year old car. I have noticed that warm/hot air is blowing in to passenger compartment from under the dash. (Almost unbearable to drive on hot days) All switches/levers are in OFF position on the climate/air conditioning controls. I was told that the vents under the dashboard are controlled by a vacuum line that opens and closes when the controls are moved thru the heat/air conditioning controls.
Can someone please point me in the right direction to find the correct vacuum line that controls the vents leading into the passenger compartment to see if the vacuum line is broken or damaged?
Thanks for all of your help in advance !
Old Sep 4, 2015 | 08:02 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Air coming in to passenger compartment with vent OFF
You can't stop the air flow no matter what in most GM cars
with a/c. Its a ancestor of the old GM flo-thru ventilation of old.
It drives me crazy on my 84! My new Impala is the same.
Funny my dads Dakota truck when you shut the fan or controls
to off it stops all air flow.................
1992 Trans Am
May 10, 2023 07:19 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Randomtask2
Aug 13, 2015 01:57 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
