What do I need to add power locks?
Old May 10, 2001 | 07:03 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
I want to add power locks to my camaro while I've got the doo panels off. What exactly do I need to do this, and is it hard?
I know I'll need the motors and switches, but what else? Are there more rods? Relays?
Thanks in advance for the help.
86 Sport Coupe, 2.8 V6, dead stock, but not for long!
Daily driver:
2000 Pontiac Grand Am SE2
"Little girls play with ponies!"
www.geocities.com/camman86
Old May 10, 2001 | 11:52 AM
Duffster@Work's Avatar
Solenoids...switches...wiring...and the bars that connect the solenoids to the lock switchs should be the whole bag...
Sounds like you've got the idea.
Duffster (age 32)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),Torker II intake, Edelbrock 1406,600cfm w/vacuum secondaries,Accel HEI Supercoil/Cap/Rotor Sparkin',84' POS 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
DuffsterCamaro@HOME.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
Old May 10, 2001 | 12:30 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Are there any relays?
Old May 11, 2001 | 06:18 PM
myposcamaro's Avatar
...patience
Old May 12, 2001 | 10:08 AM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
good point.
you can do it without them, but since you brought it up, yes...use a relay.
if you don't, you risk the possibility of 'welding' the contacts together for your switch because of the amount of current drawn.
obviously, the relay will reduce the current directly through the switch and easily be capable of conducting the proper flow of electrons to the solenoids.
Sorry I didn't think of that.
Duffster (age 32)
AND THE TIRES:
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
