Attn: MetalliCamaroRS, about your hatch...
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
How did you go about sanding and repainting the hatch strip. The one on my 91' Bird has a spot on it where the black paint came off and it's all shiny now. It also has one small spot of rust? Any suggestions? Should I remove the hatch to do this? Thanks.
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
You dont have to remove the hatch. What I did was:
1.) Masked the area first so when I sanded, I wouldn't accidentally scratch the glass/paint. Open the hatch and lay paper along the weatherstripping so most of it is outside the car. Then close the hatch and tape it down. Its easier than trying to mask it all with the hatch closed.
2.) Sanded the strip til it was shiny. Mine only had a couple areas of rust, but I chose to sand and paint the entire thing.
3.) After I sanded it, I blew the area with compressed air to get the crap off. Make sure the strip is clean.
4.) Then I sprayed it with black Rustoleum (sp?) enamel and let dry for about 8 hours. Don't let it get wet until the next day because it isn't fully dry for 24 hours.
Hope this helps. Any questions, just ask.
1992 Camaro RS
305ci automatic, all stock til I get some cash.
My 1992 RS
1992 Camaro RS
My 1992 RS
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
Duffster (age 32)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),Torker II intake, Edelbrock 1406,600cfm w/vacuum secondaries,Accel HEI Supercoil/Cap/Rotor Sparkin',84' POS 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
DuffsterCamaro@HOME.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
