Hatch pull down cable on rear lock cylinder
Old Dec 28, 2012 | 09:01 AM
texascat2's Avatar
Car: 1989 Forumla 350 WS6
Engine: 5.7 TPI:Bosch III's 22#'s
Transmission: 700-R4
Axle/Gears: BW 9 Bolt Posi- 3:27
I'm working on repairing the pull down assembly but can't remember how the cable that connects to the rear lock cylinder comes off.
Tried turning and twisting but I don't want to break it, as these are no longer available.
Any ideas for getting it off?
Thanks in advance!
Old Dec 28, 2012 | 03:49 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Hatch pull down cable on rear lock cylinder
It seems you would have to drillave to drill out those two rivets to get to the end of the cable.
Old Dec 28, 2012 | 04:51 PM
texascat2's Avatar
Thanks for replying!
The white cap that sits on the lock cylinder is the piece I was trying to get off. All it took was a little more umph and it came right off. It just snaps onto the back of the lock cylinder. The black cable is part of the actuator solenoid.
My motor is good, the relay is good, found a little corrosion in the harness plugs. About to put it back together and in the car to see if it works. The only part I didn't check was the reverse switch on the pulldown assembly.
Thanks again for posting! Great pic too!
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
