Gas tank swap?
Old Dec 31, 2012 | 02:08 PM
my87firebird's Avatar
Gas tank swap?
I am putting a 5.7 00' Z28 engine swap into my 87' firebird 2.8 V6, just wondering if that gas tanks are interchangable.
Old Dec 31, 2012 | 03:13 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Re: Gas tank swap?
Not a direct fit, but they will work. A search will yield a more definitive answer.
Old Dec 31, 2012 | 03:37 PM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
Re: Gas tank swap?
keep your origional tank and just get the rite pump for your new motor.
Old Jan 1, 2013 | 12:43 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Gas tank swap?
its easier just to swap the tank out and use the LS tank as its lighter and has baffles in it unlike the older ones. plus removal of a LS tank withe the rubber neck is so much easier to do then the metal neck that a PITA. Just my 2 cents tho
Old Jan 23, 2013 | 08:46 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Re: Gas tank swap?
if you get the nylon lines with the pump your pretty set. bolts in great. never have to deal with rust in the future either. holds 1 gallon more. need i say more. i love mine
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
