Water in Firebird Spoiler
Old Dec 31, 2012 | 06:45 PM
8T9Formula's Avatar
Car: 1989 Formula
Engine: 5.0
Transmission: 5 sp
Axle/Gears: 3.45:1
Greetings all,
Did a search for this but didn't find anything...
My '89 Formula spoiler is slowly filling with water (I live in the Seattle area w/o a garage / not the smartest choice I've ever made :-P
Has anyone run into this problem before (I can't possibly be the first...) and how did you deal with it?
I've considered drilling very small drain holes at the lowest points on each side that I can but hate to add holes where there were none... Any other ideas???
Old Jan 1, 2013 | 03:49 PM
carlos64030's Avatar
Car: 1991 Trans Am GTA
Re: Water in Firebird Spoiler
First time I've ever heard of this problem. Do you have an aftermarket fiberglass replica spoiler?
Old Jan 1, 2013 | 04:21 PM
8T9Formula's Avatar
Car: 1989 Formula
Engine: 5.0
Transmission: 5 sp
Axle/Gears: 3.45:1
Don't think so, whole car is painfully original (i.e. tired - in process of replacing original radiator and hoses today...) and no signs of rear pieces/parts being removed or replaced and no signs of any accident damage repair...
Old Jan 1, 2013 | 05:35 PM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
I know how you feel about drilling holes . but thats what I would probably do after hem and haw for 3 hrs .
Old Jan 1, 2013 | 09:06 PM
82tarecaro's Avatar
You are probably going to end up replacing it with a fiberglass reproduction. Those rubber spoilers have metal inserts that rust causing the spoiler to crack. Once that happens you might as well replace it.
Old Jan 1, 2013 | 10:58 PM
8T9Formula's Avatar
Car: 1989 Formula
Engine: 5.0
Transmission: 5 sp
Axle/Gears: 3.45:1
Thanks but that's not the issue I'm having right now.
Old Jan 2, 2013 | 06:46 AM
82tarecaro's Avatar
How do you know there is water in it?
Old Jan 2, 2013 | 02:12 PM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Yeah this is a good question. My TA spoler is split and nasty, but does not hold water, well I don't get the car wet, but when I did it did not hold water is it's in bad shape.
Old Jan 2, 2013 | 09:36 PM
8T9Formula's Avatar
Car: 1989 Formula
Engine: 5.0
Transmission: 5 sp
Axle/Gears: 3.45:1
When I raise the hatch I hear water running downhill into the sides - don't see where it gets in and nothing comes out in either up or down position.
Old Jan 2, 2013 | 10:00 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Sounds like the front or back seam has split open. I didn't have water in mine but had to reglue both the front and back seams. Keep the car covered or inside most times there is rain/snow out, so not much chance for water. Tap on the spoiler, see if you get a rattling sound - may mean you have a loose seam.
Just checked the style of spoiler, your wrap-around may not have the same seams as the one on my '84. Can't hurt to check though.
Old Jan 2, 2013 | 11:52 PM
8T9Formula's Avatar
Car: 1989 Formula
Engine: 5.0
Transmission: 5 sp
Axle/Gears: 3.45:1
Worth checking out, thanks for the suggestion - hoping the sub-freezing temps these last few and next several nights don't cause any harm before I can get the water out ... looks like a car cover is in my future!
Old Jan 3, 2013 | 10:05 AM
fyrebird68's Avatar
Drill some small holes underneath to get the water out and keep it from freezing. When you fix the seams, fix the holes.
Old Jan 3, 2013 | 10:36 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
The factory formula spoiler is a rubber sponge like material, water won't "run" thru it.
You may have a base firebird spoiler or fiberglass formula repro on it? Or, you may have water in your decklid?
Old Jan 3, 2013 | 11:04 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
As stated in a previous post, these spoilers have a steel skeleton. Water gets pulled up into them from capillary action from where they bolt to the back lid. The steel skelletons rust and delaminate, and the rust expansion of the steel cracks and distorts the urethane of the spoilers, also causing voids or channels for more water to gather in. If you have external "lumps" in your spoiler, your skeleton is rusting, and it is only a matter of time before it splits the urethane body, after which deterioration accellerates.
Repair is problematic. I sectioned the spoiler and cut out the badly rusted skeleton where it had expanded the spoiler, then glued it all back together and sealed it up. Many, MANY hours of work. The best bet is if yours is still dimensionally intact, pull it off the car, dump a bunch of rust inhibitor (Naval jelly or similar) down the studs into the steel skeleton, then seal it up with marine grade silicone, and hope for the best.
Or just step up and get an aftermarket fiberglass spoiler and be done with it.
Good luck
TA
Old Jan 3, 2013 | 02:08 PM
TTOP350's Avatar
Only steel I knew about in the spoilers was the little metal circle clips where it clips 2 window. I guessed it had something around the decklid mount also. I never have taken one apart to see the steel frame work.
I'd like to see it! Do you have pix of it??
I still dont think you'd "hear" water running thru a closed cell sponge like material.
Its a urethane like the early pontiac bumpers, to repair it properly, you need to use 3M's flexible parts repair material.
OP post a pic of the spoiler your working with.
colton_carlson
Mar 8, 2019 12:21 PM
deracer
Apr 11, 2016 12:04 AM
toronto formula
Nov 10, 2015 06:17 AM
snakeshooter
Aug 22, 2015 07:06 AM
Randomtask2
Aug 13, 2015 01:57 AM
