original door seals
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
Last time I checked They had them dont know if they were actual "OEM" But they did have them
Hecubus
Check out my new site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~200hp shot/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt.
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
Hecubus
Car: 4
Engine: 6
Transmission: 5
I just bought one at GM a couple of weeks ago... the one around the door itself, where it seals to the body. It was about $100. Seems like any piece of weatherstripping is about $100 at the dealer.
ICON Motorsports
ICON Motorsports
Car: Trans Am
Original GM outer window channel strip $27 ea
Original GM inner window channel strip $62 ea
Original GM rubber door weather strips $129ea
Door filler seals(attached to black triangle) not available from GM. Reproductions $20 for the pair.
I replaced everything, the GM items come in the original GM packaging.
All prices from www.amesperf.com
Classic Industries address is www.classicindustries.com but you can't buy anything (well anything important) on-line. You have to buy their $5 catalog and order by phone, fax or mail. While their catalog is incredible (the best I have seen and I have every one possible)they are the most expensive and take too long to deliver. They take two weeks, and every single other place I order from takes 3-5 days. I don't get it.
[This message has been edited by Nightcruzer (edited May 15, 2001).]
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Original is worth the little extra IMO
I've gotten new T-top seals (OEM/TAcreations)($134/pr)
New Door seals (SoffSeal)($80/pr)
New hatch seal (NextGen Parts)($34)
And new outer windlace from JCWhitney($30?/pr)
The only seals worth their price were the t-top seals
The SoffSeals are nice but, molded somewhat incorrectly on the ends and only have washers to hold the ends in place
Whatever crap*ssed repo hatch seals NextGen parts sells, aren't worth the cost of the packaging it came in . They do not fit correctly
The outer windlace from JCWhitney is of questionable quality,, not great but acceptable. Only thing is they come pre-smooshed on the ends for you (so you get to spend 15 mins bending them straight again)
If you can find the right outlet for any OEM GM seals,, by all means get them
*FYI the inner strips (dealer/OEM)for the windshield come attached to the plastic that lines the top of the door( the black piece that either warps or cracks),, that's why they are $62/ea
-Welders get better penetration
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
