headrest problem on GTA
Old May 8, 2001 | 05:56 PM
poncho9789's Avatar
:-( I am having a problem with the drivers headrest on my GTA. The problem is that I can't adjust the headrest with the **** for forward and backwards adjustment. When you turn the **** it just spins. I have tried pushing the headrest in and turning the **** at the same time,but that does not work. If you know what is wrong or what parts are out and were I can get them it would be greatly appreciated.
thanks guys
97 formula w/6speed,cags skipshift eleminator, hurst billet pro shifter, 30#injectors,adjustiable fuel presure regulator,Moroso cold air induction,ported mass air sensor,accell300+ ignition box, accell 9000 wires, bosch platnum4 plugs,flomaster crossflow muffler,Lingenfiter 52mm throttle body,TPIS L98 SuperProfile cam,Crane 1:6 full roller rockers,Edelbrock subframe connectors,Edelbrock strut tower brace.
Other car is a 89 GTA w/700r4w/stage 2 shift kit, corvette servo, B&M mega shifter, TPIS bigmouth intake, TPIS large tube runners, TPIS 52mm throttle body,LT1 24# injectors,GMPP LT4 hotcam,CompCams Pro magnum roller rockers, this car is currently under rebuild and restoration.
Old May 14, 2001 | 02:48 PM
poncho9789's Avatar
Someone please repily.......Help me!!!!!
Old May 16, 2001 | 10:25 PM
poncho9789's Avatar
get yo as* back up to the top.
bryan623
Mar 22, 2021 06:43 PM
Street Lethal
Apr 30, 2019 12:14 PM
The_Phoenix
Feb 4, 2016 07:10 AM
theurge
Aug 21, 2015 12:46 PM
gta power
Aug 13, 2015 06:15 AM
