How do rear hatch louvers install?
Old May 16, 2001 | 11:57 AM
bustatc's Avatar
I am thinking of getting one, but I am wondering how they install. On the directions it says you don't need to drill holes or anything. Also, does anyone have the problem of their louvers rattling around when they are driving? Thanks a lot for the help. I really want to know about this before I purchase them.
1988 Carmaro RS
Bustit.Org
To see more pictures of my camaro, go to Bustit.Org and click on the About me page!
Old May 16, 2001 | 09:33 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
they don't require any drilling. they'll attach by "clips" that mount at certain locations around the hatch, and the top mounts where the hinges usually are, will either mount that same way or else with the bolts that hold the hatch glass to its hinges. As far as rattle, keep 'em tight and/or use some foam strips to silence them...
KAM
Old May 16, 2001 | 11:03 PM
bustatc's Avatar
Thanks a lot for the info. I have heard that they rattled a lot, but you had a great idea I never really thought of, use foam. Sounds good. I think I will get them. Thanks again!!
1988 Carmaro RS
Bustit.Org
Old May 17, 2001 | 04:34 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
I have them on my car and they don't rattle. The factory set has rubber seals that sit on the window to reduce vibration. The clips attach to the window by just clipping on the edge and sticking to the glass with double sided tape. No drilling, no removing the hatch mount screws. If you get a set that requires the hatch mount screws to be removed, be sure to not overtighten them. The hatch glass will shatter when the hatch is closed or if you hit a pothole too hard.
87 IROC 350 TPI with less than 10k original miles
93 Z28 Pace Car #494 of 645
My IROC Website
Northstar Camaro Club of Minnesota
Old May 17, 2001 | 09:37 PM
bustatc's Avatar
Thanks a lot for the information, I just ordered mine today from Jcwhitney.com. I can't wait to see what they look like on my car!!!
1988 Carmaro RS
Bustit.Org
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
