finally found my squeak its in my hood hinges how can i stop it!! very annoying
Old May 17, 2001 | 12:55 AM
hookin88formula's Avatar
the other day i was adjusting my hood cause for some reason it shifted and i couldnt get my hood open.. its an ascd ram air hood. so i reefed on it a little and noticed that the hinges where making the squeaking noise i have been looking for.. anyone ever have this problem how can i make it go away!!! also it doesnt do it when its above 60 degrees out why is this?? any ideas are greatly appreciated
1988 firebird ws6 formula350tpi ascd ram air hood GT AUTO factory fiberglass wing black paint with blue pearl centerline champ 500 16x8 all around potenza 245 50 16 on front and 27x11.5 16 mickey thompson sportsman pros on the rear(real sticky!!) msd 6al box blaster 3 coil accel 8.8 race wires hooker shorty headers hooker cat back system pro shift light A pillar gauge pod and water temp and air/fuel ratio gauges autometer oil pressure gauge b&m mega console shifter vette servo custom ram air system with a 9" K&N cone filter tb coolant bypass slp runners polished plenum and runners 170* thermostat smog pump and a/c delete plus cat delete march underdrive pullies, tpis airfoil cvr high torque starter (love it) aluminum drive shaft
best 1/4 mile run of 14.44@ 96.53
this run is before the new exhaust system new sticky tires coolant by pass smog removal new runners new thermostat and new three core radiator since i would get to the line and be well over 220* aluminum drive shaft and vette servo
also 1997 grand prix gtp black with custom cold air indcution... its the my girl friends and i havent got to run it at the track yet but i will!!! yes i will... well as soon as she lets me lol.. but it seems pretty quick for a 6 and front wheel drive
Old May 17, 2001 | 12:24 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Lubricate them.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old May 17, 2001 | 04:06 PM
scauffiel's Avatar
LOL at Jim! Man, I was gonna give the same answer, but I figgered a guy with a signature like that could figure out something...
Holy monkey...
Steve
Steve's Trans Am Temple
Old May 17, 2001 | 11:38 PM
with a sig like mine? lol whats wrong with my sig? well i did already try the lubrication. i guess the next thing is to buy new ones if i can or not.. can a gm shop usually get them? i know some of the parts for are cars are not being sold anymore for somereason. thanks for the answers though
Old May 18, 2001 | 08:44 AM
scauffiel's Avatar
Well, aside from the fact that both times you posted it's three times the length of your post - nothing's wrong with it. I guess.
Did you try some white lithium grease? That usually works pretty well and seems to stick around for quite a while. Clean 'em up real good with carb cleaner, make sure they're dried off nicely, then get some lithium on them, see if that helps out.
Steve
Old May 19, 2001 | 01:13 AM
ok i will give that a try thanks
Old May 19, 2001 | 01:53 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Sometimes the little rubber 'snubbers' on the fenders that help hold the hood in line squeak. If greasing the pivots on the hinges & armour all'ing the snubbers don't help,,, maybe it's not your hood
*FYI - the reference to your sig is the fact is it's unreal long (IMO)
-Welders get better penetration
aaron7
Aug 17, 2016 06:02 PM
Polo Z03
Sep 10, 2015 06:43 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
