92 RS gauges into an 87 IROC
Old May 31, 2001 | 06:50 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
...350 TPI....
What will it take for these to work correctly with the IROC ECM and such?
Thanks!
http://kiztope.50megs.com
92 Rs 3.1/T-5
Its slowly but surely coming along.... I FIANLLY got a K&N... a little better!
AIM : Theonekiztope
ICQ: 8787542
"If it can be better than it is, make it so!" Leon Calrinsky (00)
Old May 31, 2001 | 06:51 PM
maksik7's Avatar
If they are both the same type (Electronic or mechanical, I think you just put the new dash in. I don't think you ahve to do anyhting. I could be wrong, better wait for somebody more qualified to answer.
-Max
Old May 31, 2001 | 07:15 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You'll need to swap the entire dash board, heater box and vehicle speed sensor. The gauges and dash are totally different, and the 92 uses an electronic speedo whereas the older ones (pre 1990) used a mechanical speedo.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Frozer!!!
Jan 19, 2024 04:55 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
