passenger door won't open
Old Jun 4, 2001 | 01:22 AM
chrisandkristin's Avatar
about a month ago i replaced the door handle on the passenger side but after i was done the door would not open i checked to make sure everything was hooked up and ok but it still does not open.......but it opens from the inside only ......any help
Old Jun 4, 2001 | 03:37 AM
86ZRICHIE's Avatar
take the door pannel off and check the linkage again, that's the only thing that could be wrong since it opens from the inside.
Old May 3, 2002 | 01:45 AM
cfirebird86's Avatar
Car: 86 firebird
Engine: v6
Transmission: 7004r
door won't open either
Mine has the same problem. Only it will only open from the outside.
What is the linkage? I think know but not sure since i don't know anything about cars and I am slowly learning. is the thing on the side of the door. the hole with a metal thing?
okay stop laughing at me. I told you I don't know anything about cars.
Old May 3, 2002 | 06:49 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
When they say to check the linkage it means basically make sure all the little metal rods are going where they are supposed to.
Old May 3, 2002 | 04:25 PM
tinybfl's Avatar
If your linkages are correct it could be a busted spring. The spring is located under the handle on the outside. Usually it is the culprate, outside of the rods. I had that problem on my door and I had to put the rods in. When you have the door panel off first check the rods. Worst case senario... weld the doors, remove t-tops and dukes of hazard it.
BTW on the Dukes of Hazzard what did they do if it rained?
:lala:
Old May 4, 2002 | 10:51 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
got wet...
John
1992 Trans Am
May 10, 2023 07:19 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
