hood scoop question
Old Jun 4, 2001 | 11:40 AM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
hood scoop question
Ok, i thought I would try this before buying a new hood. I have a 2 inch cowl scoop that is supposed to go onto a hood.
I am assuming bondo it onto the hood right, my question is how to attach it to the hood? rivits? I don't really want them visible when painted.
And should i cut off the area around the scoop where is is just flat? Kinda hard to describe, but a picture is in the jegs catalog in the hood section.
And finally, how would i go about cutting a hole in the hood under the cowl? what tool would I use.
Thanks for any help.
1991 Chevy truck 5.7 engine
Competition Cam 454 lift
Edelbrock Valve Springs
Holley Red Electric Fuel Pump
Eldelbrock Performer RPM Intake
Holley 750 Double Pumper
68 jets front 74 jets rear
Turbo 350 transmission
B&M shift kit
Custom drive shaft
3.73 Rear end
Flowmaster exhaust
No emissions or computer
Grant steering wheel
http://www.fbody.com/members/Camrs89/
Old Jun 4, 2001 | 04:01 PM
sleeper's Avatar
These are really prone to cracking at the edges. You're supposed to rivet through the hood and cowl and then apply a good filler to cover the rivets and the crack. Ask a body shop for some stuff that will take some flex.
Cut the hole with tin snips and then use a flexible rubber sleeve to cover the edges.
1986 Trans Am
carbed 350 - .30 over with 9.75:1 comp.
+- 315hp/390ft lbs.
700-R4 with 2500 stall
3.27 (ick!) gear
SLP 1 3/4" headers w/MAC catback and cat.
96 5 stars
SFC's, braces, arms, and a bunch more expensive stuff
no timeslips yet
Old Jun 5, 2001 | 12:07 AM
88CRUZIN's Avatar
hey camrs i was going through the same thing as you, so instead i bought a bolt on scoop that has a panel underneath the scoop. that way i was able to bolt the scoop on and no bolts showed. as for the hole i had a friend at a muffler shop cut the hole for me, all i did was measure the air cleaner onto the hood and he cut the hole out. then i put weatherstripping around it so no water would drop into the motor. hope this helps
88CRUZIN
http://community-2.webtv.net/AirSkott/PROJECT88CAMARO/
Frozer!!!
Jan 19, 2024 04:55 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
