hatch motor
Old Feb 3, 2013 | 07:41 AM
the blue one's Avatar
Car: 1988 base
Engine: 305 tbi
hatch motor
last night my electric pull down motor finally went, so im obviously going to have to buy a new one and replace it. in the mean time, what can i use to keep the hatch down? i need to drive the car every day, and i cant have it bouncing around. right now i have wire from the hook at the end of the hatch to what the back of the back seat hooks up too to keep it up. i know that this is a common problem, what can i do? also, where's the best (cheapest/ most reliable) place to get my hatch release?
Old Feb 3, 2013 | 10:34 AM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
Re: hatch motor
i drilled 2 holes in the tracks of mine and put 2 bolts through it
Old Feb 3, 2013 | 06:06 PM
Car: 1988 base
Engine: 305 tbi
Re: hatch motor
for some reason that doesnt sound like a good idea...for now i have it down, but with some wire and string. its funny, i just installed the struts........
Old Feb 10, 2013 | 12:36 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
Re: hatch motor
you can take off the back panel, undo the bolts that hold the hatch motor down there are three of them. Then simply slide it down till the hatch will shut and latch. Takes a few trial and error attempts but its the best thing you can do until you get it fixed. Mine went out a while ago and I found out it wasn't the motor. It was the switches. I took both of them apart and cleaned up the contacts and reassembled and installed them. Works great now. Just remember to adjust it right or the hatch won't open or shut right
Old Feb 10, 2013 | 12:55 PM
Buggy Disaster's Avatar
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
Re: hatch motor
I did the same thing with mine. Its been like that for the past year. It does sound bad, but if you look at the assembly you will see it is a pretty sound idea....
Old Feb 10, 2013 | 01:05 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: hatch motor
https://www.thirdgen.org/tech/hatchpulldown.pdf
Just thought I'd post a link to the Tech Article I wrote years ago on repairing these pull-down units.
As a temporary solution to hold the hatch closed, climb into the hatch and use a ratheting strap from a hole in the hatch to the body below.
Once you've diagnosed the problem, I have all the parts needed to repair them.
Lon
zayne0
Aug 24, 2015 07:22 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
1nastygta
Aug 8, 2015 07:38 PM
