i wana put a z28 grill in my 92 RS
im going to buy the grill but i want to get the factory fog light about how much are they? and how will i turn them on since i just have the standard RS grill?
Car: 1990 RS
Transmission: TH-350
i have an iroc grill and factory fog lights on my 89 rs and it was a breeze. just mount the lights, put the grill on, and what i did was connect the two wires that come out of the lights( ONE WIRE EACH) together and run it to a relay, then you ground the relay, hook the relay up to your battery, run a wire through the firewall from the relay to a switch of your choice. the run a wire from the switch to the BATT terminal on the fuse box. its really easy and a relay is only like $8. i used a SPDT relay. my car looks a million times better with that grill and the foglights. not to mention iroc rims. good luck.
you can wire them a bunch of different ways, but if you want stock lights, it will cost a fortune. You can find similar sized ones for cheaper.
91 rs, convertible, K&N, Edelbrock open element cleaner, 3.73, B&M mega-shifter, goodmark cowl-induction hood,tinted windows,MacEwen Overlays
Coming soon......"Custom" non-red material.
GVMV
Aug 16, 2015 08:01 PM
