Steel Thickness
Old Mar 7, 2013 | 06:30 PM
Col1989's Avatar
Steel Thickness
My Firebird is in need of a couple of rust hole patches and I was hoping to get started on it this spring. So far I know I'll be patching the floorboards and a hole behind the strut tower. Before I jump into it I would like to practice welding a couple of pieces of steel similar to what I'll be using. So would any of you happen to know what thickness and type of steel I should buy. Thanks in advance.
Old Mar 7, 2013 | 10:47 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: Steel Thickness
I use 18 gage it is the same or very close you won't no to difference after your done grinding it that goes for the floor pan and the apron and you can go to lowes and get a small sheet I get the 1X1 they have 16-18 and 22 ga i pay like 7 bucks a sheet
Old Mar 8, 2013 | 10:29 AM
Col1989's Avatar
Re: Steel Thickness
Thanks for the info, I'll go check out my lowe's and see what they got
Old Mar 8, 2013 | 10:49 AM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Re: Steel Thickness
find a metal shop and you can get a 4x8 for around 30 dollars
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
3rdgenparts
May 21, 2016 11:50 PM
darwinprice
17
Oct 11, 2015 11:51 PM
skinny z
Oct 5, 2015 06:23 PM
roysatikas
Sep 22, 2015 08:15 PM
