split folding to solid rear seat
Old Jun 20, 2001 | 11:25 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
can you switch a split folding rear seat with a solid rear seat and vice versa? will they bolt right in, or do some mods need to be made?
Old Jun 20, 2001 | 11:30 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
If going from split to solid you need to cut off the two hinge points mounted to the driveshaft tunnel. If going from solid to split you can cut this piece out of a wrecked car and either weld or rivet it in place. I would say it's easier to go split to solid.
90 RS Convertible
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Jun 22, 2001 | 01:04 AM
Kandied91z's Avatar
don't cut off the posts.......just in case you ever want to put the old one's back! just push the seats in place with a little more force; they will fit fine, paint them black to hide them if you have to.
Old Jun 22, 2001 | 04:49 PM
Thirdgenfbody.com's Avatar
If you need a solid back seat ive got one gray out of a 87 Camaro ill make a deal with you.
Arthur-
1985 IROC Restoration In Progress
http://www.thirdgenfbody.com/projiroc/
Member # 98 of The Las Vegas F-Body Association
www.lvfbody.com
Old Jun 23, 2001 | 11:27 PM
maksik7's Avatar
Definetley dont cut them, I went from split to solid, just paint the stubs black and nobody will notice.
-Max
Old Jun 26, 2001 | 02:14 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Here's my seats, went from split to solid.
You can't even see the bar on the hump,
High Speed Run: 157mph
Best 1/4 mile run: 14.94@91.67mph
WS6 Trans Am.
View My Ride @ thirdgen.org
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
MORREALE5
Sep 13, 2015 09:16 PM
z28addict8490
Aug 7, 2015 08:48 PM
