How do I go about fixxing a saggy headliner??
Old Jun 27, 2001 | 07:43 PM
Metallica383's Avatar
I know you can buy the 3M stuff but do you just use the same material that is on the board or do you have to replace it also. The piece I have is in great shape so is the board but I just need to know how to go about fixxing it myself.
Old Jun 27, 2001 | 07:47 PM
GndPrx's Avatar
If the headliner is sagging, odds are that the material has seperated from the foam that is attached to the back of it. If your board is in good shape, then you can just replace the material. About $10/yard from JoAnne Fabrics or the like. 3M Super 77 or 90 works fine to reapply.
Carl
CarAudio Resources
Old Jun 27, 2001 | 07:55 PM
Do you make sure that all the foam is off the board before replacing it or is there any prep that is needed before applying?
Old Jun 27, 2001 | 08:04 PM
GndPrx's Avatar
Yeah, after you remove the material, take a bristle scrub brush and clean off all of the old foam. Once that is done, spray both the board and the back of the new material with the spray adheasive. Let it sit until both sides tack up and apply the new material starting from the center and working your way out.
Carl
CarAudio Resources
Old Jun 27, 2001 | 08:11 PM
I have a local joann fabrics around here do you asj for headliner material and how much will I need?
Thanks for the info
Old Jun 27, 2001 | 08:18 PM
GndPrx's Avatar
I bought 2 yards so I would have plenty extra. Wanted enough to cover the T-Top inserts as well. 1.5yards is probably enough to cover fine, but I would buy 2 just in case.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Rousseau92maro
Feb 1, 2016 05:12 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
MORREALE5
Sep 13, 2015 09:01 PM
blackbmagic
Sep 8, 2015 10:36 PM
